08.15.2008, 05:10 PM
There is only the bec and rx involved in this equation as the esc red wire is removed.
Either your end points are way off, you are using massive amounts of trim (both of these don't kill a servo instantly) or the voltage is too high - do you have a voltmeter to check the output?
