Thread: 4s in a TC3
B15
08.16.2008, 01:45 AM
Originally Posted by speedracer1129 View Post
Too hot in what sense?? When you set up a car for 100mph speeds, you are not going to have a car that will play for 10 minutes straight! We get about 10-15 passes of about 600 feet with the setup before it hits about 170-180 on the motor and 150-170 on the ESC, We then let it cool down for about 30 minutes before running them again. This setup also consists of no extra cooling added!!
Ive killed 2 stock center driveshafts w/ my 4s tc3. They flex in teh middle then centrifugal force flings them out, shattering receiver cases on the way.
I tried a 5700 on 4s with similar results to what you described. If thats what you call reliable, then sure its reliable. IMO if it cant survive a full battery it isnt reliable. My 4600 can run for a whole battery while geared for over 100 without heat issues. Ive only managed to do that a couple times because crashes at those speeds are pretty spectacular (and expensive). Thats with no fans or extra heatsinks, I guess the airflow is pretty good at those speeds.
