Originally Posted by ReV:-O
but the 1521 will be better because it has a slightly higher kv rating and its more powerful so i can gear it higher and get better top speed without sacrificing any low end.
with a more powerful/bigger motor, will that use up more battery even though it says it has the same amps?
a 1515 would be plenty of power for you and good luck with your drivetrain you will need upgrades....I get 50 mph with my Revo and that is about as fast as you want to go with a MT
