Thread: My new E-REVO
BAD 1
08.16.2008, 01:20 PM
Thanks Guys. as far as rx lipo pk. i have the H O lipo regulator. i thought it has a cutoff on it. Not to mention that i check & charge my bats way to often. i would really like to stick with the rx pk. As far as my extra 2700uf-25v cap. leave it or replace it with 3 small ones as Brian sug. BrianG great to hear from you. i app. your input and the way you make things look easy. As far as run time which is also a main con due to racing. I went to a page that had run times and saw a set up close to mine. can u var my time using 2x7.4 - 8000 max amps & 1515/1Y give or take 25sec or so.
