MetalMan
MetalMan's Avatar
08.16.2008, 10:41 PM
Originally Posted by Geogenesis13 View Post
allright thanks oh would i need anything else to make it work in a erevo except for the single motor mount
The KB-45's bolt spacing is 30mm, and it uses 4mm screws. Standard 540 motors (36mm diameter) use a 25mm or 1in. bolt spacing, and 3mm screws. In other words, the KB-45 will not fit without modifying the motor plate, but even then there probably isn't enough material on the mount to let the motor sit properly.
