08.16.2008, 11:00 PM
Originally Posted by MetalMan View Post
The KB-45's bolt spacing is 30mm, and it uses 4mm screws. Standard 540 motors (36mm diameter) use a 25mm or 1in. bolt spacing, and 3mm screws. In other words, the KB-45 will not fit without modifying the motor plate, but even then there probably isn't enough material on the mount to let the motor sit properly.
It will fit in an e revo, as the side mount has a 30mm hole spacing option that will fit a m4 thread bolt. Only issue is that the kb45 has a 6mm shaft, so pinion choice is limited. Mike may be able to get the mod1 pinions made with 6mm bore...
Kershaw designs has the 6mm bore pinions... in a few different tooth choices.
I have run the L can kb45 motors with good success. Not bad temps and they sure are powerful. They do draw some amps so good batteries are required.
Check here: http://www.traxxas.com/PDF-Library/5605_manual.pdf page 31
