Originally Posted by Takedown
New idea! Ben brought up the idea of using dual ESC's to soak up the enormous shock of the outrunner. I am probably going to run dual 100a HV ESC's from bidproduct that can handle 10s each. I will run the two 5s lipos in series to make 10s lipo and then run them in parrallel to both esc's. The ESC's will be ran in parallel to the giant outrunner. Kind of a complicated setup but I hope this works.
This might have been gone over at some point on this forum. If I recall correctly, this won't work since the two brains boards would need to be synchronized with each other so they fire the correct phase at exactly the same time. But since that's not possible without extensive modifications, there's a good chance they would fry each other.
SH Z-Car, Custom Crawler, 8s Savage,
12s XTM XLB 1/7 buggy,
4wd 4-link rear/IFS Pro4 truck,
Custom Hyper 10 Short Course,
Belt-Drive Mammoth ST 1/8 truggy, 4s 17.5 MM Pro HPI Blitz
