08.17.2008, 07:48 PM
ouu ok makes sense. so since my 7xl on 4s is at 35k rpms, which is right around the sweet spot or even the max rpm for a feigao motor, will i be able to gear even higher....maybe a 24/58 if my motor was only at the 170 degrees range during the entire run?
right now im at 25/68 geared for 40 adjusted mph and 41 max speed. the 24/58 will give me 49 max and 46 adjusted.
so as long as my motor temps are under 180, i should be cool to do this set up right...even though im overgeared like craaaaazy??
