Originally Posted by lincpimp
My V1 has a few hours on it with 4s lipo and a 1515 1.5d, and no issues so far.
I did clearance the bottom of the case so that the fan plug did not rest on it. I also enlarged the opening that the signal and switch wires exit thru. And I added some high density foam underneath the main pcb to support it. That way the board could not knock against the bottom cover during a hard landing. My fan still works too.
does that void your warranty?
and has this problem been fixed on the v2's?
