Pdelcast
Pdelcast's Avatar
08.18.2008, 05:46 PM
Originally Posted by RBMike View Post
Patrick, I think after replacing the fan at home last night, that should qualify as a cold start correct?
Should be. I'd check the connector though -- make sure that it is attached correctly. Like I said, the fan controller is designed to make the fan run all the time if it fails.
Patrick
Patrick del Castillo
President, Principle Engineer
