10.19.2005, 04:11 PM
The minimum input voltage of the Koolflights UBEC is 6.5V. It says in the manual the regulator will go into bypass mode below 6.5V, which is not a bad thing at all.
If you want to use a warrior 9920 on less than 8 cells, you should get an UBEC or a receiver pack.
