coolrunnings
08.19.2008, 02:51 AM
That's right the money you spend on a water cooling system can be used to upgrade to a neu...then cooling is not an issue at all. I just put a 40mm 12volt fan on a chinese motor and lowered my temps at least 30deg and the fan was only about 3 bucks to buy off ebay and took 5 minutes to install. You can also cut vents in your body and really get some fresh air moving around and that helps alot too. Air flow rocks!
