Thread: Batch 2 V2 MMM
Sneaky Pete
08.19.2008, 09:52 AM
Jhautz- might I enquire as to which dremel attachment you used to make such a clean job?
It looks like the edges of the case bottom are all pretty much even. I would think you could get a piece of acrylic to lay over the case. Then make an opening in the acrylic (.5"?). Then use the depth gauge attachment on the dremel to sit on top of the acrylic. Set the depth of the bit and go to it. I would make sure to put the case bottom on a non-slip rubber mat so it doesn't move around.
