JThiessen
JThiessen's Avatar
08.19.2008, 01:08 PM
7 to 9 lbs is a huge difference. If its 7 lbs (which I seriously doubt), then you should be down in the 20-30WT. Over that, and you will be up into the 50-60wt. Also depends on which spring you run.
