Ofna Ultra GTP Conversion!
Ofna Ultra GTP Conversion! - 08.20.2008, 05:03 PM
So, my next project begins.
I just got home from the LHS, ordered the Ultra GTP kit as well as the Porsche 911 body for it!
I can't pick them up until next monday or tuesday though because I'm taking a trip with my dad.
I'm going to run my Hacker C-50Maxx, MM, and 5s with a TrueRC BEC. Also going to run a HS-645MG (oddly I have them in all of my projects)
Gearing will be about 14/45 (58mph)
Calculated:
Differential Ratio: 3.142857142857143
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 45
Pinion Tooth Count: 14
Total Voltage: 18.5
Motor KV: 3033
Tire Diameter (inches): 3.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.21 : 1
Total Ratio: 10.10204 : 1
Tire Circumference (inches): 11.94 inches (303.23 mm)
Total Motor Speed: 56110.5 RPM
Vehicle Speed: 62.79 mph (100.87 km/h)
Estimated Adjusted Speed: 57 mph (92 km/h) - 9% loss
Effective KV Value: 3033
KT constant: 0.45 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
