Originally Posted by jnev
ffactory - There was a diagram posted somewhere on the forum that shows exactly what you said. Using those 4 mounting tabs, it mounts straight to a another mount on the chassis. As long as those tabs on the ESC are metal, it should be a very durable and secure way of mounting the ESC.
EDIT: I didn't find the post, but here is the exploded view of how the ESC is mounted:
http://www.losi.com/ProdInfo/Files/8IGHTEexplode2.pdf
That a very clever design of how the gear mesh is adjusted too.  I actually like that better because you can loosen only one screw instead of loosening two in a very awkward position.
While looking there, I also found the body for the "E-8ight":
http://www.losi.com/Products/Feature...rodId=LOSA8097
Although not much info on it...
You have been a busy boy , thanks for those links
Surely the mounting tabs are metal and that motor mount is brilliant , only needing one screw from the top to adjust mesh .
It's a pain in the ass adjusting mesh in the X2 with the RCM mount , i have to remove the whole radio tray and then my hex wrench still doesn't fit to get to the bottom screw . I have to use on of those cheap L shaped hex wrenches that come in the car kits.
I think this was in the planning for a long time from Losi , very impressed
