kulangflow
Never Fast Enough
kulangflow's Avatar
08.22.2008, 12:58 PM
Those pins are definitely the worst thing about the ETree. They easily get bent when you're driving if your install is a bit loose/weak. I wish they had a plastic cap on the pins and mounting tabs of some sort for the whole unit.
The weight of the batt/esc wires bouncing around is often stronger than the velcro I use, so it gets loose. I use it in several different vehicles and take it out to hook it up to the PC, so I' haven't been motivated to come up with a super secure mount.
It's not a HUGE deal, but it can obviously cause problems.
