08.22.2008, 07:57 PM
Is the brake curve set to anything other than default? I would re-flash the ESC firmware and set all ESC settings to default and go from there. On the radio side, I'd make sure the trim is at 0, and the EPA is 100% for both forwards and reverse. And if your radio has a "quick brake adjustment" (like Spektrum), make sure that is at 100% as well.
