Finnster
KillaHurtz
Finnster's Avatar
08.24.2008, 03:17 PM
No, if the lvc is set lower than 3v per cell then it will damage the lipo. The only time you should have issues with the lvc is when you set it higher than the pack voltage. So a 5s fully charged pack is 21v, if you set the lvc to 22v it would have issues. 15v is the minimum setting for 5s lipo.
I suspect you may have firmware issues. Have you tried downloading 1.17 firmware into the controller? and then going back to 1.19 after that?
That I haven't done. I'm guessing its not another LVC bug then. I'l try it out today and see what happens. I got flash my MM too as the brakes on it arent working right. lol..line em up.
