08.25.2008, 12:06 AM
I'm using CC 4mm bullet connectors between the ESC and motor, soldered the same way I did the 5mms on my MGM and Neu and it works beautifully. It's a b50 8s currently geared significantly lower than my Mamba Max 5700 was. I also noticed that the wires from the battery to the ESC were extremely hot after trying to run it on the ground a few seconds and the battery wires were rather hot.
