microdiladum
microdiladum's Avatar
10.21.2005, 07:37 PM
Got my revo roller yesterday! Took the seller 2 weeks to ship after I had to contact him about it and it was poorly packaged, but whatever.
Anyways Mike, I was wondering would it also be possible to use two of the longer center Revo shafts with this chassis? If the lengths are around 86mm and 102mm it seems to me that they would work with only very minor modification.
I am sure I will end up with some of your shafts, but it would be nice to use these at first.
The about 102mm shaft:
And the 86mm shaft. It could be shortened easly if it is a little to long, but it seems to work nicely:
I understand the lengths with this type of shaft might be slightly different and I just guessed where the dogbones might be since that is where you siad the measurments where from. Anything in the 102 and 86mm ballpark would seem to work. Is there somthing I am missing?
Also the shafts fit great on the e-maxx tranny output shaft with only a little removel of materal.
