VintageMA
VintageMA's Avatar
08.25.2008, 10:36 PM
Originally Posted by GO-RIDE.com View Post
What setup are you running on the .5? Mine does great on just about everything. My 10th truck is a bit more stable overall due to both greater width and length, but 4wd .5 is more fun to drive. With truck tires I run the rear bones a bit below level and set the front ride height for chassis level. With buggy tires I run rear bones level and front again set up to level the chassis with the rear. I had some tip over problems in the past, but it was because I was running too stiff of springs.
Running the medium blue in back and white hard in front with stock oil weight. With the Anacondas on ashpalt it is rock solid and hard to flip. With bow ties, dirt hawgs etc on grass it flip pretty easy and is a little bouncy on the rough stuff. I tend to run a little bit of pre-load with the rears just a touch higher than level and the fronts a bit more as the front tends to bottom out when braking. If you want I can check on the mounting holes used for the front and rear.
“Everyone has a right to be stupid; some people just abuse the privilege.”
