Originally Posted by BrianG
If you are electronically inclined, a voltage sensing switch can be added to the output of the CCBEC so if the output goes above a set value (~6.5v should be good), the circuit simply cuts power. Basically just an op-amp with the CCBEC output voltage fed to the + input of the diff amp, and create a reference voltage (6.5v) using a zener and resistor on the - input of the diff amp. The output of the op amp can be a PNP transistor (probably a darlington) or a FET that actually does the switching. Should be simple enough.
That's a logical and pretty simple design, but it's been a long time since I etched a circuit and would have to spend as much on chemicals and supplies as buying one of those linked ones. Also - wouldn't the transistor have to support the full battery voltage so that it doesn't burn out just from overvoltage across terminals?
