08.26.2008, 11:41 PM
sweet!
Thanks, I'll get a couple more pics on the morning.
Originally Posted by gimpygolden View Post
Make sure you shim you fr and rr diffs. My rear ring and pinion is getting a little clicky.
I've never shimmed a diff. I might need some help.
Very true, Hongnor k series diffs (most ofna vehicles save for the hyper line) are not the best, and require a good shim job...
Read above post.
By the way I run 8xl on 5s 22 tooth pin on foams and it is retarded. I usually set EPA to 85% (140% is max) still hard to control.Have fun
Thanks, 8xl on 5s must be wild! Can't imagine what my setup will be like!
Looks like a fun project RV0. I never had any issues with the hacker when I ran it on 5s.
Hopefully it turns out well. I found a hiccup though, when installing the foam front bumper the holes are too small for the 4mm supplied screws. I bored them out bot am now just realizing that I could have used 3mm screws. Stupid me.
Also will this be made into a rally kit. Onroad's arent to exciting IMO because all you can do is street driving. Atleast when your rally converted you can go offroad somewhat.
I might convert ro rally, haven't decided yet.
