10.22.2005, 08:52 AM
Dan's Stockade is a pretty big truck, isn't it? The 7xl is larger because it is an "xl" ("L"= long, "XL" = extra long). The "sxl" will have more torque and will more easily pull a heavy truck around. The 7xl will need taller gearing to achieve the same speed as the 8L also. Either motor will work quite well on 12 cells. For more cells, the 7xl will be the better choice.
Welcome to the forums, too!
