08.28.2008, 09:20 AM
If you decide to keep your VXL 3S system then the CRT.5 would be a great choice. Yes, it is smaller than a 1/10 truck, but it's a blast to drive. If you keep your VXL system and want something bigger than a Hot Bodies LS10 (full 1/10 4wd truck) is a popular choice, although not as high quality as a CRT.5.
If you go with a 1/8 buggy or truggy then you will need more motor and to heavily modify your MM to keep the temps down and run strong. You can run 3S in a 1/8 buggy but most prefer 4S or more.
E-8ight - Tekin RX8 2000kv/4S
