R00ST
08.28.2008, 04:05 PM
but what about the axle diameter? For instance I cannot put tmaxx 14mm hexes on my rustler as the axle on the rusty is smaller (would be sloppy).
Are there hexes that directly fit the axles on the ls10, or do you need adaptors for the different sizes?
http://www3.towerhobbies.com/cgi-bin...?&I=LXTBP2&P=7
That is what i use on my rustler. I have two packages of them, as my rustler (like these trucks) have equal length a-arms (I widened mine) so it would look dumb with two different offset adaptors! I use all 4 smaller ones, as the longer ones are just too damn long (they are like 1 1/4 inch...the smaller are like 3/4 inch).
So think I can use 4 of these smaller ones on either the ls10 or the crt.5 axles to run my 17mm wheels? Should help give me some more width as long as the axle diameters are the same between the crt.5/ls10 and rustler.
