08.28.2008, 04:06 PM
...You would need to remove the inductor, the switcher chip (MSOP-8) and the mosfets (the two TSOP-6 parts.)
Patrick
Patrick, to be totally clear, the components to remove are the ones in the pic below correct? This will completely disable the built-in BEC? I would;ve thought that just removing the coil would be enough...
I know I'll have to "inject" external 6v power into the MMM throttle power line so the internal circuits can have their power.
