Originally Posted by Arct1k
Stick with the CRT .5 - there are a few going on RCU including one with the v1 RCM extended chassis. The VXL is like an M can - in between s and L and should be fine.
They are both made by feigao.
The vxl motor is no differnt in size than a s can feigao, and the windings are slightly shorter. Magnet length is the same. A l can will do better if you plan to run heavier tires and high top speed.
