08.28.2008, 08:52 PM
Well, if you want motor brakes, that pretty much leaves out the Tekno conversion route. An RCM motor mount and some type of battery tray would be easy enough. It's just a matter of mounting the ESC and Rx.
Oh, and for the tranny, since you already have the nitro one, you could simply lock it in second gear just like the regular Revo. Saves a few bucks that way. The gearing is slightly different, but you can make that up with the spur/pinion.
