08.28.2008, 11:49 PM
You stole thw words right out of my mouth... 1y is a 4s motor, 6s for speed runs only in a light truck.
If he gears it down that will lower the load quite a bit, and then the batteries should be able to keep up. I would use a 5s lipo with that motor myself, but gearing will be the cheapest way to get good temps...
Here is the spur.. I meant to type 62 tooth, that with the 12t pinion will work...
http://www3.towerhobbies.com/cgi-bin...?&I=LXLMY5&P=7
