Originally Posted by BL_RV0
Summer school still?! When does school start?
Only problem I see is that having the shaft have to be so long because of the flipped CD. The slipper would inevitably help with stress, but it may still be an issue. This could be great for larger outrunners with ~8mm shafts IMO. The smaller outrunners with 5mm shafts may not have the power... Especially the lower efficiency ones. Depends I suppose.
Use a long enough shaft, and have a front support with a bearing to handle the load. I personally like the idea, and may try to mock something up on a buggy this weekend.
