Vxl???
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Vxl??? - 09.02.2008, 01:08 AM
Look it has been done before and it proves to be more problematic in the long run. The VXL system just does not hold up well in the EMaxx unless you gear for really slow speeds. Like stated earlier since you are in Germany go with either the MGM or Schulz controller, and use either a Neu 1515, Madusa, or even a Plettenberg Big Maximum. With those choices you will have much more fun for your money, and you are able to get tech support much easier from those companies there. Don't waste your time or money on the VXL in a Maxx. It just does not work well.
