If the emaxx is seriously 7.7lbs, which would involve removing 1/2 the stuff on it, grinding the chassis to bare minumum, and using light weight wheels and tires it can work. I refer you to Tempted from the traxxas forums, search his posts there
LINK, Anything else even if you gear at 15t pinion you will fry the motor and esc.
