starscream
RC-Monster TQ
starscream's Avatar
09.02.2008, 03:06 PM
Originally Posted by Gee View Post
Thanks for the write up rootar.
For the gear (name?) on the outside of the differential. Are the different sizes that can be used? Like differnt size spurs.
James I installed the one you had with the LS10 and it's working great. Is it the crt .5 diff or the ls10?
The spur I sent you is the crt.5 diff. I'm not aware of any other size spurs for the crt.5 other than the stock 46T. The kyosho plastic spurs fit the diff but the bearing size is different.
Maybe someone could get the Monster to make a 2mm aluminum shim for the 10x15mm bearing?
Ha Ha
