coolrunnings
09.03.2008, 06:40 AM
Yea the block of wood trick works good but right now I just have a pair of pliers with a rubber band around the handles to hold the plugs, then I set the wire in the hole and start pouring in the solder...of course having a really good solder station helps big time I have the hako 936 that goes up to 900deg in a flash.
