09.03.2008, 11:52 AM
Like Plettenberg's rig kinda- I've wanted a Cd for the Gmaxx chassis for ages, and Mike can custom build one too (seen some photos on the traxxas forum), but the main issue is you are forced to use a 44t spur, which isnt so bad, but even going up one tooth on pinion makes a big difference to final drive ratio, and there is hardly any room for manouver to go smaller, without using lots of MOD1 spurs and pinions, and those aint cheap. Im thinking about making my own X-braces that will allow a CD to be used, only with more room to use larger spurs and such. Fun project- will use my bent X-braces as the template once my replacements arrive.
