bdebde
That's All Folks!
bdebde's Avatar
09.03.2008, 10:37 PM
Originally Posted by The Cow View Post
This looks about rite correct? have you ever used thier software? how does it compare to the cc... From the other post looks like i am on piont for my goals just need to address the ESc. If i go with the EVO30's and the 1521/1.5d this is alot more KV and he was doing 57 on 5cell..... Do you agree it would be best to over motor and esc and then detune through the software in hopes of keeping the sytem working easy while performing?
Thanks again for the input my friends
Heath
The MGM software is not bad, it even gives you a readout of rpm, amps, volts, and max temp after a run.
I would just adjust your speed with gearing, and you can use the punch (on MMM) or accel time (MGM) to tame things down a bit.
