Thread: newb ?
09.04.2008, 01:50 PM
DO NOT DO THIS UNLESS YOU HAVE AN OPTO ESC - YOU WILL BREAK SOMETHING.
This setup is very specific to where you want to power the esc from the rx battery as the internal ESC BEC has been removed or does not exist!
This is very unusual - normally the internal ESC's bec is still left to power the brain board and the red wire on the ESC lead must be removed!
Which ESC are you using - Brian's script is the best tool to look at.
Exactly! This is a special diagram made specifically for the MMM BEC removal mod. Using a BEC and a receiver pack at the same time could cause issues.
