Thread: Batch 2 V2 MMM
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.04.2008, 10:14 PM
ugggh.....has anyone else had problems soldering the battery leads to deans plugs? I cant get my Hako to melt the solder they have on the wire. I've had it on high, and set it on the wire for up to 5 minutes, and got NO molten solder. Just to check my iron, I soldered up a deans to one of my Deans wires, and it worked fine.
Chop off their pre tinned ends. I assume it is the lead free solder they are using that makes it hard to solder. I busted out my 80 watt iron and it did the trick but that stuff is a pain.
