Shark413
Shark413's Avatar
09.04.2008, 10:32 PM
Hi, I was also worried about the Tekno RX plate blocking the optional Traxxas rear brake so I started working on a rear rx tray. I cut a small piece of CF and cut some spacers out of 6mm tube. I then used long screws to bolt it down to the rear shock mount. Worked great, but it blocked access to the rear shocks (I like to adjust the oil/pistons a lot) and once I recieved the Tekno RX plate I found that it cleared the rear brake, so I removed my homemade tray. Also, if you run the wires on top, the wire will have no problem reaching the ESC mounted on the tranny. Tekno parts are top notch.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
