Originally Posted by hemiblas
Got my MMM and gave it a good workout. First impressions are this thing is massive and sturdy compared to my other speed controllers. I was too afraid to program it or do anything so I calibrated it and just ran it. In 95 degree weather and after about 10 minutes the MMM was at 118 degrees, the batteries were at 100 and the motor at 180 (doh). This was just speed runs with lots of stopping and starting. Everything seems to be working well. The controller has an incredibly smooth startup. You could rock crawl with this thing. I am pretty happy. I have 0 cogging and 0 glitching.
My setup is as follows:
I'm running a stock 3905 Emaxx with a feigao 7xl geared 20, 68 for about 38mph. I have 2 truerc 7.4V 8000mah 10C lipos in series and an airtronics 2.4 ghz radio.
I plan on running this thing at least once per day so hopefully it lasts. I'll report back if anything happens. I'm hoping this is a solid setup that holds up for a while.
your motor is running hot due to the kv rating, try going to a 9XL and it will run cooler unless you gear down, but you would probubly have to gear for 30 mph for it to run cool enough...but whats the fun in that....
