09.05.2008, 02:53 PM
There are a few ways to do that with normal PC PSU depending on design:
1: Look for a small PCB mounted pot and make small adjustments to see if it tweaks the voltage or something else.
2: Load down another rail. If this is truly a 12v PSU only, that can't be done.
3: Look for a voltage feedback wire and trick the PSU into thinking the voltage is lower than it really is, so it boosts the output.
