09.06.2008, 12:21 AM
Originally Posted by slimthelineman
has anyone tried running a modified r1 on 6s with any luck? would like to try one in my buggy. i have owned many tekins over the years with good luck and in fact still have a functional G12c i purchased when it hit the shelves looooong ago (whenever that was). Other than the caps and the external bec is there a chance this might work?
Modified one would work with 6S with no problem as long as your battery voltage below 27V, otherwise it would clamp it to 27V level.
Stock ones, if you can keep temp down then probably, but I won't recommend that...
And would agree with BlackedOutREVO about setup, keep it conservative and it would work, try to push it - it would fail.
