Thread: Batch 2 V2 MMM
xtremelimits285
E8ight T
xtremelimits285's Avatar
09.07.2008, 12:20 PM
The wire's don't have male bullets on them on one end? Mine did, and the only thing I had to solder was my choice of ends to connect the motor (I used 6mm bullets for that). I did attempt to use 4mm, but the wire wouldn't fit into the socket on the bullet.
Originally Posted by JeffEmbracedDC View Post
As did all of mine..
no theres no males soldered on any of the wires, both sides of the wires are tinned..
i tryed a set of 4mm's an crap is the tinned solder hard to melt, i had a friend try to put on the 4mm's and no luck, my 80-120watt gun needed a new tip, try or 30mins..
ill just get some 6mm's or 6.5mm's and have the hobby shop down the road put them on, as it probley only takes the 5mis..
im going to use 2 screews to hold down my MMM to my RCPD top plate
and also use 2 zipties just incase...
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
  Send a message via MSN to xtremelimits285
