Electric Dave
09.07.2008, 06:43 PM
Originally Posted by starscream View Post
I always run my packs in series as I've personally found more uses for smaller capacity high voltage packs than larger capacity lower voltage packs.
Then again, I've always run higher voltage than most.
Did you mean parallel?
Small capacity and high voltage are what parallel is all about.
Large capacity and low voltage are where seres comes into play...
Just want to make sure I understand your post.
