Thread: Home-made UBEC
MetalMan
MetalMan's Avatar
10.25.2005, 08:39 PM
It is made, and it also has a 4s Lipo regulator on the same circuit board. But since I don't have a controller to use, my testing only get as far as using a variable voltage power supply to see where the cutoff device would cut off. I also saw that a BMS-620mg can pull more than an amp easily! The cool thing about this regulator is that when the amp draw goes up, the voltage does also! It is rated at 5volts, but under enough amps it went up to about 5.30v.
