Sammus
Sammus's Avatar
09.09.2008, 08:20 AM
Not really, 6s lipo on 2200kv is well within its rated maximum rpm, and I think the idea is that at their recommended voltage, gearing and general setup (I think it is safe to say this is offered as an upgrade to the e monsters, which at the moment are the emaxx and erevo), which the average user will be following, the average current draw should be close to peak efficiency of the motor.
Running lower voltage and gearing up you would draw way more current and the motor would be significantly less efficient = more heat.
