Shark413
Shark413's Avatar
09.09.2008, 11:04 PM
Here are some shots of the pushrod mods I made. By using the small red Revo washers (one on each end) I could raise or lower the truck (and the center of gravity) by about 1/4 per washer. So with both washers out the truck would sit almost 1/2 lower. Of course when running it that low you need to stiffen the suspension (stiffer springs and thicker oil). When set to the lower setting the truck handles more like a 1/8 buggy, you can rail the turns. With it set at the higher level it handles like a stock Slayer, lots of suspension action and sliding power drifts.
Stock pushrods on top (silver) modded ones on the bottom (green).
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
