09.10.2008, 12:39 PM
I run a 1515 1.5d in my erevo on 4s lipo. It runs well on 4s, but would not suggest running it on 6s. The 1y or 2.5d would be better suited to 6s in that heavy truck.
I have an aftershock converted to BL. I run a hacker c50 11xl (1500kv) on 6s lipo with a MMM. I am curently using a air of polyquest 4500 30c 3s lipos in series. Those batts are rated quite high, but will still get warm with this setup. I would say that a set of 5000mah 25c 3s lipos would be the minimum, and if I were to buy lipos again I would buy the polyquest 6000 25c 3s lipos. Unless you go with a large capacity pack, like a true rc 6s 8000 15c pack, the 15c-20c packs will not keep up.
If you want to run the 1.5d stick to 4s, and you will need very good lipos. The polyquest 6000 25c lipos would be the best bet for a 4s pack. I would sell the motor and get the 2.5d and go 6s, that will yeild the best results with that heavy truck.
